How to represent Frequency in Hertz rather than Frequency bin.
Setting the offset, does not result to a spectrum with a negative and positive frequency.
 I want a spetrum that is centeret at 0 and showing both positive and negative frequencies.
I dont know what to connect in my offset, to achieve it.
Message 11 of 18
(1,543 Views)
Then what did you get?
Message 12 of 18
(1,541 Views)
It just multiplied the x-axis to a larger number.
Here's the result
Message 13 of 18
(1,528 Views)
Hi gijude,
when you just multplied the x axis values you most probably changed the X-Axis.Range.Multiplier. You need to change the X-Axis.Range.Offset value!
Message 14 of 18
(1,504 Views)
Hi Sir GerdW,
I dont understand. Can you tell me what particular setting do i need to have in my offset. ? Please refer to my screenshot
Message 15 of 18
(1,497 Views)
Hi gijude,
all this has been told to you before:
Message 16 of 18
(1,488 Views)
Here's the result
That looks like you made a positive offset instead of a negative one.
Message 17 of 18
(1,480 Views)
@GerdW wrote:
Hi gijude,
there's also a built in functionality of the fft.vi
https://forums.ni.com/t5/LabVIEW/how-can-i-implement-fftshift-in-LabVIEW/m-p/3077671#M879128
Message 18 of 18
(1,464 Views)
