Resetable, Adjustable, Running Average
I have a loop that is spitting out a single number each time.  I need to be able to take a running average of the value.  That is easy with a while loop and shift registers but what I need is to be able to reset it and also change the number of averages.  So when the operator says he wants some unknown amount of averaging the loop starts and with each iteration it gives me an output of the average so far and then when the full number of averages is reached it resets and starts again.
(3,334 Views)
This should give you some ideas to get started. It uses the loop "i" as the data values.
Lynn
(3,324 Views)
Isn't there a pt-by-pt VI that does exactly this?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,309 Views)
Mike...
Like Mean PtByPt?
(3,281 Views)
Yeah, that's the one.
Mike...
LabVIEW Champion
(3,269 Views)
Morning and thanks for the feedback.  I had already searched the forums and tried that pt-to-pt vi and did not get the results I wanted.  I will mock it up again when I get a chance.  I don't remember what it was not doing from my requirements but will pass it on when I do.
(3,205 Views)
