How to remove project warning
Hi all,
I'm using LabVIEW 8.6.1 project window here. How can I get rid of the warning shown in the image?
The file has been moved as indicated. Refresh does not work, nor save all, I can not delete the warning under the "Files" or "Items" tab. Any ideas?
TIA
-Martin
Certified LabVIEW Architect
(4,533 Views)
Hi Martin,
did you try "clear conflicts"?
Mike
(4,531 Views)
Hi Mike - do you mean "Resolve conflicts" as this is disabled. I can not find "Clear conflicts".
-Martin
(4,524 Views)
Hi Martin,
yes, that's what i meant. It shouldn't be a problem, because it's only in the "Dependencies".
Mike
(4,522 Views)
Accepted by topic author Martin.D
Martin.D wrote:
[...] I can not delete the warning under the "Files" or "Items" tab[...]
The reason why you cannot delete it is because the item is part of the dependencies. It shows up because some code in your application refers to this file position, but the file (DLL!) is not found there.
So in order to resolve the conflict, you have to find the Call Library Function Node which does not refer to the updated location of the DLL. "Reroute" this CLFN to the new position/name of the DLL and the entry should disappear.
Note that this entry should not effect the functionality of the application since DLLs are searched in other paths if not found in the expected one....
hope this helps,
Norbert
Norbert
Expert: Geometry
(4,519 Views)
Thanks Norbert - warning is now cleared.
(4,495 Views)
Then please mark Norbert's reply as the solution to your question rather than you own thank you message.  You can unmark your reply as the solution by going to the Options menu to the upper right hand corner of the message.
(4,470 Views)
