How to remove error 59 which occurred while using Send Email Using Smtp Client .VI in Labview 2013.
Hi,I am trying to run Send Email Using Smtp Client .VI in Labview 2013 examples ,but it gives error 59.Please can anyone suggest how to remove the error.The printscreen is attached below.
(6,081 Views)
You may need to check your settings. For Gmail you need to use smtp.gmail.com on port 465, enable TLS, and you will need to specify your username and password.
(6,070 Views)
Thanks for the help.I changed my settings,now error363500 is coming.
(6,059 Views)
In reply to the previous post Here is the print screen attached for error 363500.
(6,056 Views)
Enabled tls and set username and password .still the error comes.
(6,052 Views)
Accepted by qwerty7
Apologies, I've just tried this myself, the port number you need is port 587 with TLS.
(6,019 Views)
Thanks for the help,but i have set the parameters right but still it does not work for me.Please suggest me reasons and how to correct them.
(5,936 Views)
