How to remotely control a LabView program Via a PDA
I took the PDA remote control example and tried to intergrate it into the PDA target.   Currently I have pocketPC Errors.
RP_ClientRequestControl is a missing VI or C file and RP_OpenConnectionToServer is a missing VI or C file.  The details for these two errors are there was an error building the executable.  Please check the VI's or C files that were added.
(5,464 Views)
Hi Thejoeblack,
Where is the PDA Remote Control example you're referring to?  This KnowledgeBase has one suggestion, but I'm not sure it applies to your application.
James R.
(5,413 Views)
James,
This is where the problem lies,  The example was taken from a the remotepanalmethods-client.VI and placed inside of the PDA target.  I had to delete the error subVIs to allow me to run the program.
The program hung up because it was missing a RP_clientrequestcontrol VI/Code and RE_openconnectiontoserver VI/Code.
(5,405 Views)
