How to reinitialize the shift register after stop?
Whenever I stop the program I would like to reinitiate the value that the case structure gives me. It is giving me the maximum value.
After I stop, I want it to go back to zero.
Any suggestion?
(3,407 Views)
Accepted by topic author RM1991
You can reinitialize it upon start using the Initializer Terminal on the feedback node.
aputman
(3,398 Views)
In addition, I think you can remove that entire inner while loop and it would still work the same. Less code = less places for bugs to hide! 😄
And yes, simply initialize the feedback node as has been said.
There is also "ptbypt min&max" which will do all that for you directly. try it!
(3,383 Views)
Also what's the point of the formula node?  It's unnecessary, as is the comparison equal to 0.
aputman
(3,369 Views)
Yes, there are plenty more things wrong with this code. We only scratched the surface. 🙂
(3,358 Views)
