How to record the the time line ?
we would like to tell you roughly about our project using labview. Our program is like measuring running rail vibration using accelerometer, NI-9233 and NI-9103.  There are some recording parts . For example, if vibration is greater than 50g, we need to record and save files to show the exact time and the range of the acceleration,etc .Our problem is that how to record and save the files using labview.Thank you very much for your time . We are looking forward for your reply.
Best Regards,
kiT
(2,612 Views)
Hi kit,
you can use the DAQmx vi´s to measure your data for example as waveform. If you have your data you can write it to a file. There are a lot of examples in the Example finder.
Hope it helps.
Mike
Message Edited by MikeS81 on 05-22-2008 11:36 AM
(2,607 Views)
(2,581 Views)
