FPGA 7831R Damage
I incorrectly connected 13v to some DIO pins of my FPGA 7831R card and now they do not operate. The manual says 7v max for DIO.
The pins in question are the DIO 2,3,6,7 of the MIO connector and I was using these as DIO inputs to monitor 2 relays for activations.
On an activation I returned Hall pulses to simulate a motor movement.
I have moved my software to other pins and connected these to the 5v output from my target board as opposed to the relay outputs and it works fine but is there any way of repairing the damage ?
Is there SMD fuses for these pins that I can replace ?
(2,596 Views)
If the board it self is damaged, I would advise contacting your local NI Branch to organise a return and repair. They will be able to process this for you. However, if you go ahead with trying to repair it your self, it might void the warranty.
I believe you are in the UK, please find the contact details here.
(2,575 Views)
