How to read temperature data from binary file?
Is it possible to read temperature data from binary (unknown file type) like this file with LabVIEW?
(3,567 Views)
Accepted by topic author Pusak
Hi Pusak,
the general answer is NO.
In your specific case I guess you want to do this:
Is this the expected content of your data file? (Use a DBL array constant…)
(3,549 Views)
WOW! Thanks a lot GerdW.
How did you know that?
(3,540 Views)
Hi Pusak,
I know the binary format of floating point numbers…
(3,529 Views)
Here is a slightly more simple solution.
(3,518 Views)
Excellent, thanks so much!
(3,470 Views)
