How to read temperature data from binary file?
Is it possible to read temperature data from binary (unknown file type) like this file with LabVIEW?
(3,532 Views)
Accepted by Pusak
Hi Pusak,
the general answer is NO.
In your specific case I guess you want to do this:
Is this the expected content of your data file? (Use a DBL array constant…)
(3,514 Views)
WOW! Thanks a lot GerdW.
How did you know that?
(3,505 Views)
Hi Pusak,
I know the binary format of floating point numbers…
(3,494 Views)
Accepted by Pusak
Here is a slightly more simple solution.
(3,483 Views)
Excellent, thanks so much!
(3,435 Views)
