How to read from two channels?
Hi there. I have a dumb question about labview.
I wonder how I can read from two channels of an osilliscope? another
question is, what I read from GPIB address is string or data?
thank you!
redoo
(3,072 Views)
You're going to have to be a little more specific in your question. What kind of scope? What driver are you using? Do you want to read a waveform or measurement? As an example, if you're using the IVI scope class driver, to return a waveform, you use IVIScope Read Waveform.vi once for each channel. It returns the waveform as an array of DBLs. If you're using a low level VISA read, the data comes across the bus as a string. Any conversion to numeric data you'll have to do yourself and will require studying the instrument manual to understand the format.
(3,072 Views)
Thanks! I guess I'm even new in asking questions. 😛
My osilliscope is Tektronix 520 and Tektronix 684B. what driver do you
mean? I need a driver to use the osilliscope? What I want to read is a
waveform about 100 ns long.
thank you.
(3,072 Views)
Hi
You can download more than 1600 Instrument drivers from the NI website. When you install a driver you have different VI's (special for your instrument) and with them you can programm your instrument. Each driver has always a getting started VI. With it you can check the features of the instrument from LV.
On this site you will find the ID for your oscilloscopes: http://search.ni.com/query.html?lk=1&col=alldocs&nh=500&rf=3&ql=&pw=595&qp=%2BContentType%3AInstrumentDriver+%2BIDNetInstrumentType%3A%22Oscilloscopes%22+%2BIDNetManufacturer%3A%22Tektronix%22&qt=&layout=IDNet
Luca
(3,072 Views)
Thanks! I found them. 🙂
but they don't have 684B. Instead, i found 684 and 684A. I'll try both.
redoo
"mustang"
??????:506500000005000000A7760000-1019262487000@exchange.ni.com...
> Hi
(3,072 Views)
