Call Library Function Error after upgrading to Win2000
Can anyone please help? I'm all out of ideas. We were recently require to update our PC from Windows 98 to 2000 and ever since the upgrade, the data acquisition VIs that LabVIEW provides do not work. The problem occurs in multiple subVIs in the AI Buffer Read.vi. The specific error that I'm seeing is: "Call Library Function: function not found in library" When I pop up on the node, the dll and the function name both appear to be correct. Thanks for your time.
(3,116 Views)
You don't mention which version of NI-DAQ that you're using. Have you done an upgrade to a version that supports Win2K?
(3,116 Views)
Thanks for the help. You were exactly right.
(3,116 Views)
(3,116 Views)
I suggest uninstalling and reinstalling NI-DAQ from the web. It sounds like you do not have the proper support files for LV. Goto www.ni.com >> download software >> drivers and updates >> current software version >> NI-DAQ. Be sure to read the directions--you will need to get at least two files.
Jeremy Braden
(3,116 Views)
Thanks for the help. I really appreciate it.
(3,116 Views)
