How to read *.bin file
We use PCI 6014 and labView 7.0 to save the signal as *.BIN file, I want to read it in Matlab, please tell me the head file and the resolution of the *.BIN file.
(3,002 Views)
I'm not sure if I'm on the right track here, but if you're saving the file through LV, then a look at the code should reveal everything you need to know about the file. The easiest thing may be to write a VI to convert the data into a more Matlab-compatible format. This requires also that you already know the format of the file, in which case the problem is already solved. Ah Catch 22.....
Otherwise, if a *.bin is a standard filetype I have no experience with is, sorry.
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(3,002 Views)
Hello -
This KnowledgeBase discusses importing data from LabVIEW to Matlab. Good luck with your project and have a great day!
Becky B.
Applications Engineer
Becky Linton
Field Engineer
Office: 734-464-2463
Cell: 248-709-2822
Email: becky.linton@ni.com
(3,002 Views)
