How to read MAX configuration file programatically in LabVIEW?
Hi Partha
1) When saving FieldPoint Configuration file, it is saved as .iak file
2) If you have a .iak file then yes you can list the FieldPoint devices mentioned in the .iak file, but one thing in this case is that it will only show the devices that where there  when the .iak was saved & not the currently available fieldpoint devices on the network.
3) For detecting DAQ Devices, you can use DAQmx Propery Node, it will list down all the devices connected to the current controller in which you run the program to read the DAQmx devices.
About .nce : - let me check it !!
Thanks & Regards,
Rajan
Message 11 of 15
(1,918 Views)
Hi Rajan,
Have you done it programatically from LV? If so, can you share those VIs?
- Partha ( CLD until Oct 2027 🙂 )
Message 12 of 15
(1,915 Views)
Hi Partha,
see this link please. At the end you will find a description where you can read all the installed devices. I tried it and you will find also the nonNI devices there. It´s only usable if you run windows there.
Hope it helps.
Mike
Message 13 of 15
(1,887 Views)
Hi Mike,
Thanks for the link; but I cant open it because of my company's policy that it fals under shopping & merchandising category.
So, will it be possible for you to upload it in the form of pdf here?
Is it a program or tutorial or something else?
Message 14 of 15
(1,871 Views)
Hi Partha,
it´s a knowledge base article. The attached picture shows the part i mean.
Mike
Message Edited by MikeS81 on 08-28-2008 07:06 AM
Message 15 of 15
(1,868 Views)
