How to properly generate a sin wave and take it fourier transform?
@ZainAli02 wrote:
yes, that should result in an array
what is "that"?
Message 11 of 15
(568 Views)
By "that" I meant an array can be built into a waveform by defining dt.
Message 12 of 15
(533 Views)
No that takes an array and results in a waveform. Have you solved your problem yet?
Message 13 of 15
(524 Views)
Yes, I had solved my problem. Thank you for all the help, I apologize for my extremely late response.
Message 14 of 15
(452 Views)
You are numerically generating a sine wave at multiple time points using finite-precision floating-point numbers (and the sine function does not give exact values).  In particular, the amplitude values for frequencies other than 0.1 are probably not 0, but some extremely tiny (and hence unreliable) value, making the estimation of the phase more-or-less meaningless.
Message 15 of 15
(446 Views)
