Build an application created on Windows, on Linux
Hello guys, i'm on Labview 20. I have 2 installations, one on Windows 10 and one on Linux Ubuntu 22. When i create an application on Windows and try to open it on my Linux installation, some fonts and buttons dimensions are larger. How can i solve? Why my graphic template on windows, results larger on linux? Don't change nothing if i set the same monitor resolution
(666 Views)
Yes, it is. 15 pt on Windows is approximately 12 pt on Mac and 11 pt on Linux.
Refer to this topic: Re: FP Geometry - Mac vs Win.
I would like to recommend do not change fonts on the Front Panel manually, leave default Application Font, but change size in the settings only if needed and supply INI file with desired font's sizes, then they will be more or less same (you will never get exact 1:1 appearance on Linux and Windows, but close enough).
(661 Views)
(636 Views)
