How to programmatically scroll the vertical bar of a mixed signal graph
I am trying to programmatically scroll the vertical bar of a mixed signal graph. I imagine this should be straight forward (or so I thought) but for some reason when I write to the plot area bounds property to move the "top" and "bottom" the write does not take effect. I am using LV 2015 sp1 64-bit ....don't know if it has to do with what I am using, but would like to if this works OK for anyone else or if there is some other approach ? Thanks
[BADGE NAME]
(2,894 Views)
You need to use XScale -> Range -> Maximum and Minimum properties:
(2,830 Views)
Are you trying to vertically scroll through the entire mixed signal graph, or in individual plot areas. If you modify the code that PiDi posted to ‘YScale’, it allows for scrolling in individual plot areas.
Brian.D
NI Product Owner
VeriStand
(2,803 Views)
Brian,
thanks for the feedback. I am scrolling the entire graph, not just a single plot area.
[BADGE NAME]
(2,727 Views)
