Generating Excel graph problem
Hello, I am trying to generate a report for my vi and I have some problems when I generate graphs in Excel. The png file shows the problem. Every single graph that I create from labview has those huge blank spaces that so far I can't eliminate. In the top righ there is a graph generated from excel, Is there any way that graphs generated from labview look like that one? If not at least I would like to know how to eliminate the blank margins. I'm using Labview 2016 and office 2016. Maybe a compatibility issue? Because I have tried the labview examples and I have the same problems. I also attach the xlsx file
(2,857 Views)
What is unusual is how small the inner part is compared to the frame (if you look at the chart object size properties you will see that the scales were resized to 65-69%). If I just double click on a graph and then click outside it resizes. I would try adding the Excel Quit Graph.vi before adding a new graph to close the MsGraph ActiveX references.
Ben64
(2,812 Views)
