How to program the AGILENT 34980A in order to measure a time (in milliseconds) ?
I am performing tests on a relay with 8 contacts. The tool I use for that is Agilent 34980 A.
How can l measure the switching time of my relay contacts, through the Agilent vis?
Thank you in advance.
(3,937 Views)
Hi there,
I wondered how you were getting on with this?
Are you happy with the physical set up and theory of the capture and are looking for help in translating this to the Agilient VIs? Or would you like help with the set up also?
Scott
(3,840 Views)
Hello.
I am fine with the set up. Thank you for asking. For the moment, my concern is getting results through programmation (Agilent VI).
Bolduc.
(3,810 Views)
Have you managed to perform this operation with the physical unit yet?
We can translate the functions you used to the LabVIEW driver.
(3,703 Views)
