How to program keyboard to boolean?
Ah I answered my last question
Message 11 of 14
(1,028 Views)
Is there a way I can attach a control boolean to the case structure while still working with the down key?
Message 12 of 14
(1,023 Views)
Accepted by topic author break406
Here is a case structure inside of an event structure that will do exactly what you want.
Not to sound preachy or anything, but the questions you asked showed a pretty significant lack of understanding on how case structures work. Since they are one of the most fundamental parts of LabVIEW programming, I suggest you spend awhile familiarizing yourself with them before moving on.  The help files are useful, but just playing around for awhile is also useful.  Good luck!
Edit: I forgot to add this to the VI, but you should also look in to local variables. You just right click on the terminal in the back panel, -> Create -> Local Variable
Message 13 of 14
(1,016 Views)
What I really need is for the LED to turn off as I release the arrow key. I was hoping to do that using a control i'll look into it more. Thanks i'll accept this as a solution
Message 14 of 14
(997 Views)
