How to print a .prn file programatically?
I need to print a .prn file after a test successfully completes. The file can be sent to the default printer. Is this possible to do?
(7,011 Views)
What kind of programming language are you using? I tried to do it by calling print command(MS-DOS) in a batch file to print prn file.
Bill
(7,002 Views)
I wish to print a .prn file on demand using LabVIEW 6.1. After a successful completion of an actuator production test, a label is to be printed for the product.
(6,990 Views)
You could use a system exec command (found in the Communications pallette). Just pass the command and the filename to this command.
(6,970 Views)
Hello CoryJCI,
This can be accomplished by using the System Exec VI with the print command. Attached is an example of how this may be accomplished.
You may also find this article of interest in printing with network printers through MS-DOS based commands.
How to print to a network printer from an MS-DOS-based program in Windows XP
Matt F
(6,968 Views)
