How to prevent the LabVIEW about dialog from being available from the menu on a MAC built LV app.
I have a LV application that I have built with the application builder for MAC.  When I run this app, the menu has an entry for each menu item I specified along with an entry that matches my applications name.  If I select the entry that matches my app name and then hit about, The about LabVIEW  dialog is displayed.  I have not been able to find a way to either suppress this behavior or redirect it to a VI to display about information related to my application.  Ideally I can just get rid of it since it makes no sense to my customers as to why a LabVIEW dialog would appear when they would expect to get information on my application.
I am using:
LabVIEW  2010
App builder for MAC
OSX 10.5.8
Thanks in advance for your help.
(2,339 Views)
Hi sjp,
maybe that's the MAC way to ensure your LicenseAgreement, that you accepted when using LabVIEW:
A. Deployment and Distribution Requirements.
(1.) You include the following copyright notice "Copyright © [insert year] National Instruments Corporation. All Rights Reserved." in the Authorized Application′s About Box (if applicable) and in (i) any applicable written documentation or, (ii) if no such documentation exists, in a "read me" or other .txt file distributed with each copy of the Authorized Application; (you may instead, or in addition, include your own copyright notice with the notice(s) required above, but in no event may you remove or alter any copyright, patent, trademark, or other legal notices or disclaimers that exist in the SOFTWARE; and, with respect to any runtime engines for the SOFTWARE and any Driver Interface Software that you may include as part of or together with your Authorized Application, your copyright notice shall be understood as protecting NI’s copyrights in the SOFTWARE and shall not be understood as meaning that you have any copyright in or with respect to any SOFTWARE);
(2,338 Views)
