Formatting a mixed signal graph
How to remove the empty spaces in the mixed signal graph ?
When I load the mixed signal graph with data there is a very large portion between the graphs and the label which is blank (white)
I want to get rid of this blank area and increase the size(length) of the graphs how to do this.
Please see attached screen shot.
(2,784 Views)
Accepted by topic author vbs
Any appearance setting that cannot be found under the Properties of your graph can be modified by setting you indicator/control as a customized control. To do this, right click the graph; go to “Advanced” and “Customize…” You will get a new window were you can customize your control. Below the “View” menu you will find a button to “Change to Customize Mode”, after you click on it you will be able to resize and move every individual part of this graph.
If you need additional information about custom controls the following article could be very useful:
Creating Custom Controls, Indicators, and Type Definitions
https://www.ni.com/docs/en-US/bundle/labview/page/creating-custom-controls-indicators-and-type-defin...
Thanks!
Jorge
Certified LabVIEW Associate Developer (CLAD)
(2,757 Views)
Thanks that worked, it creates and saves the graph control as an customized control, But that is ok.. that is what I need.
(2,746 Views)
