How to plot this data in 3d curve in labview 5.1?
Hi
People here have helped me ..but i have more doubts and problems.
I am not posting my program because it is so big, so i am posting a example which it is seemed.
In this vi which i am sending,i need to plot many curves, with updates.
Aix X with time and/ or date,aix Y with 4 channels, and aix Z,the temperatures of each channel.
I need this for continue may final graduation project.
I am using labview 5.1 because it is the version available in my university.
Sorry by my english.
And i will apreciate helping me.
Thanks a lot
Rafael -Labview 5.1
Brasil
Message 1 of 24
(5,221 Views)
Hello Rafael !
I don't know if plotting 3D curves is possible in LabVIEW 5.1, I started using LabVIEW with 6i version and I am now using LV 7.1.
I don't really understand why you need 3D curves, can't you just plot 4 2D curves with axis X time and axis Y temperature ?
In case you really need 3D and LV 5.1 allows only 2D (I'm not sure about that) you still can use the color of the curve as a a third dimension.
Sorry not to be able to help more and good luck for your final graduation project.
Epictetus
Antoine Chalons
Message 2 of 24
(5,218 Views)
Hi
I have just read ate the forum in some messages  that it is possible 3d curves in labview 5.1,and there is a function which do it.
I my project it is necessary to view the graph 3d,if you wanna,i can explain the project later.
Now i need urgently help.
Thakns a lot
Rafael
Labview 5.1
Brasil
Message 3 of 24
(5,211 Views)
Hi
My project stopped becuase i don' t know to do this.
Anybody help me urgently please!!!!
Rafael
Labview 5.1
Brasil
Message 4 of 24
(5,199 Views)
Hello Rafael,
I wish I could give you a hand, but I don't have LabVIEW 5.1 (only 7.1.1).
Check the LabVIEW Examples, they are very helpfull. I'm sure you will find some vi to plot 3D curves.
Good luke.
Epictetus
Antoine Chalons
Message 5 of 24
(5,192 Views)
Hi
The only example that i have it is very weak and doesn~t help.
Thanks but i still ait help.
Rafael
Labview 5.1
Brasil
Message 6 of 24
(5,190 Views)
Hi Rafael,
Few of us still have LV 5.1.
Please post jpg images of your code and you may get a little more help.
The CW 3-d graph is a rather complex widget and open ended Q's are hard to cover. Also please post a set of data to help us help you.
Depending on the details it take less than 10 minutes to wire this up, once we know what needs wired.
Ben
Message 7 of 24
(5,175 Views)
Hi
I am posting a jpg that you ask.
I have already sent a vi of the prorgram.
I need to put a aix X of date or/and time,aix Y with 4 channels,and Z with temperature of this channels.
I need a graph 3d curves and update this in real time.The update has to be the same time of reading of the table that i sent you.
Now,could you help me?
Thanks a lot
Rafael
Brasil
Labview 5.1
Urgnetly
ps:sorry by my english but i am ina hurry
Message 8 of 24
(5,158 Views)
Ssssssss,
I found the following example that I think may prove useful. It shows how to plot two sine waves on the same 3d plot. Now these are surfaces, not 2D functions so there are some differences, but I think you'll be able to use the program as a template to move forward. In your development.
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B123AE0CBA19111EE034080020E74861&p_...
Best Regards,
Chris C
Applications Engineering
Message 9 of 24
(5,137 Views)
Chris , i used the link you sent but doesn't solve my problems.
The example you passed me draw surfaces.
I need to draw  a curve for 3 termistor for each time.And i need to update them.
Let me explain better:
I have to read 3 channels in time t1,t2t3,etc..
For each time i will have curve.
If i decide to read as default 10 s,in 60s i will have 6 curves in my graph,in 70s,7 graph.(This is the update,but i have to see all the curves).
I am posting the doc with the example which i am working.
I need too to put the coordenates correctly, i can 't put time in aix.
If you thought confuse,notice me!
I am in a hurry and i need help urgently.
If necessary i could send the VI.
Thanks a lot and help me!
Labview 5.1
Rafael
Brasil
Message 10 of 24
(5,108 Views)
