How to plot graph for 3 parameters one in x axis and other 2 in y access?
I need to plot graph for different parameters(2 plots).
X-axis - Time in 24hr mode in the format hr:min:sec
Y1-axis - Temperature 1
Y2-axis - Temperature 2
A table with the sample of data in a VI is attached.
Kindly help me in plotting the same.
(4,559 Views)
Accepted by Mr.7
Unless the x-values are spaced equally (are they always?), you need an xy graph, not a waveform graph.
Here are two possibilities, one for each graph type. There are many other ways to do this.
(4,549 Views)
Thank you very much :manhappy:
Yes, the x axis-values are not equally spaced, will use xy graph.
(4,541 Views)
I want to plot graph with Actual date-time  vs  temp-1,temp-2,temp-3,temp-4 (4 plot).
Please help me.
I am beginner and studying Labview..
James
(2,476 Views)
