How to plot amplitude vs phase angle ??
hii.. i have data that is stored in TDMS format time as X axis and amplitude as Y axis. basically i acquired that data from oscilloscope with 2500 point for each frame. Now i want to plot whole TDMS file with ampliutde as Y axis and phase angle as X axis on one graph how do i plot this ?
(5,155 Views)
Hi pady,
please explain where your "phase angle" signal is coming from…
General answer: to plot "y vs x" data sets I advise to use the XY graph.
(5,146 Views)
thanks,
acutally m acquiring data from oscilooscope with time i want to convert that time data into phase and plot amplitude vs phase plz help mi. i am new LabVIEW learner.
(5,120 Views)
Accepted by pady07
Hi pady,
again: YOU have to explain how to convert your time data into phase data!
After you explained the conversion the programming part is easy…
(5,117 Views)
Phase (Φ)= 2πft
i want phase angle for each amplitude value. i attached below my program file jpg and one TDMS sheet. check attachment and help mi. m extremely sry i don't understand how to explain m totally confused plz see below attachment i hope u get what i want to said
(5,103 Views)
Hi pady,
in your phase formula you have two unknown/variable values: f and t.
Where do you measure f? What's the value of f?
You CANNOT measure any phase value as long as you only know the amplitudes!
On your VI:
Why do you use DDT at all? Why do you convert waveforms to DDT to convert them back to waveforms?
Cleaning up a VI isn't your most important item?
(5,091 Views)
ok sry that is my mistake u said two unknown variable but time data is there and if we consider standard frequency of that oscilloscope that i know is 50 Hz than it is possible to convert into phase or not?? how?
(5,061 Views)
