How to plot a xyz-points 3D-graph with different colours?
Dear all,
I tried to plot xyz points from an csv-file as 3D graph. The basic VI works as intended.
Now I want to add an additonal feature to the VI. This new feature should display, depending on the measurement result from the csv-file, if a xyz-point is valid (=green point) or out of threshold (=red point).
Reading the measurement result of each point works fine, but I can only change the colour of all xyz-points in my 3D graph and not just a single xyz-point. So either all green or all red.
Has anyone a clue how to get the wanted result?
note: I attached the xyz-coordinate csv-file but not the results column.
(2,192 Views)
Accepted by topic author Evermax
If you use a scatter plot, you can make 2 separate plots and color them red and green. You can probably do it with a line plot too, but I didn't mess around enough.
(2,153 Views)
Thank you for the hint!
I will try to make 3 separate plots, one for the red points, one for the green points and one to plot the lines between.
(2,115 Views)
