‎05-06-2015 09:30 AM
Hi !
I am currently using a DAQ Assistant to get dynamic data from 2 channels input.
With a splitting VI, I substract one to the other and plot them ( Graphic named 1 )
Then I use a VI which transform the Dynamic result of the soustraction into an array, in order to calculate its mean.
After that step, when I turn my script ON, I am well capable to observe dynamically my mean evolve from an indicator
BUT
I can not observe it plotted VS time as I would like.
In other words, from the dynamic data I have value VS time, I get the mean of it over time, and I would like to be able to plot it back VS time, with the previous mean points plotted.
All I can get now is a single point moving up and down, because it is lacking time data.
I attached to this post a simple represenation of my issue, I hope I provide enough information.
I just would like to be able to plot like the window on the left, and not having the one on the right ...
Thank you !
‎05-06-2015 09:55 AM
‎05-06-2015 09:59 AM
Hi !
Thank you for your quick answer.
I see what you mean, it makes sense.
But how will I be able to plot the mean VS time if now I have all my data splited into arrays ?
I am not sure I talk clearly ... In other ords how will I rebind that mean and Time into one wire to send it into graph VI ?
‎05-06-2015 10:12 AM
