How to place a reference (strict) of a cluster into a Type Def. control?
Example use: In for instance queued message handler there is a cluster holding references to front panel indicators and controls.
I have a type-def'ed front panel cluster which I need to add to this cluster of references.
In the typedef for front panel controls (shown above), I place a control refnum then
Right click it ->Select Vi Server Class -> Generic -> GObject -> Control -> Cluster -> Cluster.
This does however not produce a typedef of the strict type which I need.
How can I acieve this?
I manage to place controls into the typedef cluster of common simple types (numbers, strings etc.) by placing a control refnum in the cluster and (for string control reference)
Right click ->Select Vi Server Class -> Generic -> GObject -> Control -> String -> String
Think this works because they dont need to be strict typed.
(5,306 Views)
Accepted by heel
Drop an instance of your cluster type def on the FP then drag it into the referance.
"Should be" isn't "Is" -Jay
(5,287 Views)
Thanks Jeff, exactly what I was missing.
(5,271 Views)
Its one of those "Tricks" that once you know it you know it and wonder; "Why didn't anyone tell me I could just do THAT?"  it happens all the time!
(5,264 Views)
