How to pause and resume a while loop with a button
Hello everyone!
I'm getting back into LabVIEW after a few years and I can't figure out, what on the face of it seems like a simple problem!
All I want to do is to have a while loop in which for the purposes of illustration I have the "random number 0-1" function inside, and I want to be able to pause and resume this using a button. There are some other posts on the forum which are very similar and the make use of "event structures". The problem I run into is that I can get the random number genarator to start generating however the pause will not stop this!
I have a feeling I am making a silly mistake - but I can't figure or google my way out of the problem! I have attached my solution so far!
Cheers!
Message 1 of 8
(7,896 Views)
Accepted by topic author QuantumPenguin
i made an example (you can drag and drop the picture into a labview block diagram >=2014
hope it helps (i just made 2 snippets, its the same program)
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 2 of 8
(7,869 Views)
That's a great solution thanks! Also I had no idea you can drag and drop images in - amazing!!
I have a seperate question but related to my problem. Do you know if there is a way to programaticaly create switch functionality from a latch button. Basically I want to have something that constantly outputs eiter true or false or is in a constant state of true or false but when it recives a true/false "pulse" from the latch on relase button it will flip its state - is there a function already in labview to do this?
Message 3 of 8
(7,861 Views)
if you want to do it yourself:
while in block-diagram, mark everything, and EDIT -> Create Snippet
:cheers:
Message 4 of 8
(7,855 Views)
The first problem with this solution is that you don't need local variables at all here.  The stop button should be a "latching" button and the terminal should be inside of its value change event case.  This will allow it to unlatch.  The Run and Pause buttons should also be inside the event case where they are used.  Heck, all of those terminals should be used instead of the local variables.
Secondly, to go to anything more than a basic program, this really should be done in a state machine where the random number generation should be its own state that then calls the idle state (where and event structure is).  So when the pause is done, you just make sure to come back to the idle state instead of going on to the random number generation state.
Message 5 of 8
(7,834 Views)
@crossrulz i know for this little example local-vars are not needed,
but i found when getting a little larger with my vis,
i always use them.
any specific reason, that might not be a good idea?
<edit> except for race conditions</edit>
Message 6 of 8
(7,810 Views)
i always use them.
Memory (each local is a copy of the data).  Speed (the terminal is a little faster than the local).  They also make it hard to read a diagram.  If you find yourself using a lot of locals, then you are likely not using a good architecture and you would likely benefit from a State Machine, Producer/Consumer, Queues, User Events, and/or (Queued) Message Handlers.
Message 7 of 8
(7,795 Views)
Thanks for the input everyone. I will lookup state machines and have a play!
Message 8 of 8
(7,776 Views)
