How to pause a vi programmatically (with many loops and cases)
Accepted by ASH2020
Your event case is probably has the checkbox set to lock the front panel until the event completes.  Since the Mouse Down event is still running, the front panel is locked and you can't press the stop button to cause the inner loop to stop, which is what you need to have happen for the event case to complete and the front panel to unlock.
It is a catch-22.  Event structures really should not have long running code or loops that need other interactions to stop them inside of them.
Read Caveats and Recommendations when Using Events in LabVIEW - LabVIEW 2016 Help
Message 21 of 25
(1,605 Views)
Thank you. You are a star! That was the vital piece of information I was looking for through this whole thread. I had missed that check box and now it works beautifully. Well done.
BTW, there is no getting away from the fact I have to loop 10 times, at 4 second intervals and I have to have a way of pausing it. Thanks again.
Andrew
Message 22 of 25
(1,601 Views)
Andrew
Ummm... no.  You are using a band-aid to cover bad habits.  The proper thing to do is make it so you don't have to lock the front panel.
Bill
CLD
(Mid-Level minion.)
Message 23 of 25
(1,583 Views)
Andrew
The front panel isn't locked now. That's the whole point. That's what the problem was all along. And BTW, people don't learn very well if they are criticised. I have done my best, it is moderately tidy and it works very well, oh, and I've delivered it on time.
Message 24 of 25
(1,577 Views)
Hi Andrew,
We didn't say so.
We suggested to implement a producer-consumer scheme, maybe combined with state machines. You still should handle UI events with an event structure!
If it's ok for you and you done your job, it might be ok in general.
As long as nobody else has to support any future development based on your VI…
Message 25 of 25
(1,563 Views)
