How to pass data.
In the subVI, your cluster is 4 Booleans and 2 I32. The indicator in both the subVI and main is 4 Booleans and 2 DBL. Since you didn not provide the .ctl, I had to disconnect from the type def. I also don't understand how you created the reference in the subVI. It is not at all the same as the reference in the main. A simple way is that in the main, when you create a reference, just drag it to the front panel of the subVI. With the correct reference and changing the representation of the numerics in the cluster, I don't have any coercion dots. You also don't have to use the To Variant and you will be writing to a strict reference. Here's a modified subVI. I also fixed your connector pane. Convention is to place inputs on the left side and outputs on the right side. Yours were the opposite.
Message 21 of 23
(891 Views)
Thanks! Sry forgot to attach the cluster file. That solved my red dots problems ^___^.
I understand that the reference in the subvi is diferent than the main. I tried what u mention, in my main project and on my example , but no luck(it only worked on my example). I'm really starting to think that my project is buged. 😞
PD: Im Andrea, I forgot im on my coworkers computer ^^
Message Edited by zamjir on 09-27-2007 12:34 PM
Message Edited by zamjir on 09-27-2007 12:35 PM
Message 22 of 23
(888 Views)
Well there was a bug in my project.
The way around would be using share variable ^_^.
ty for all the help 🙂
Thanks!
Andrea - Software Developer
Message 23 of 23
(848 Views)
