How to output frequency into graphs
This is my first time using labview software. I have a function generator attached to SCB-68 which is then attached to a NI PXle-6363. I want to calculate the frequency and amplitude of the wave. I also want to graph the overall, after the test has been concluded, values of both and then allow the user to save the graphs and values to a given file of their choice. I already have graphs that show the values of each but only while it is running, not an overall graph. I have attached a screenshot of my front panel and block diagram. I am building up to wanting to hook up a high frequency microphone and listening to bearings while in use. I want to prepare graphs and values of the frequency to determine which bearings are good. We are planning on having a returned frequency of ~60-80kHz. I am also confused on setting the samples to read and rate under the DAQ assistant settings. Can I also put a start button that will initiate obtaining readings from the function generator or microphone?
Thanks much!
(2,622 Views)
You "can" do most of what you've asked in your post.  Unfortunately I do not have LabVIEW installed on this machine to help.
One thing that will benefit others in helping you:
1. Attach the actual LabVIEW code.  A picture is worth a thousand words.  But code is worth a million.
2. If you really insist on uploading a picture, try a Code Snippet.  They are easy to make and are pictures of your code with special LabVIEW meta-data hidden in them.  They allow you to actually open the picture with LabVIEW and have LabVIEW re-create the code for you to use.
This will allow others to actually help your more easily.  Especially once you start having more complex issues that a single picture cannot clear up.
Best of luck and welcome to LabVIEW!  It's really great and you will learn to love it!
If someone helped you out, please select their post as the solution and/or give them Kudos!
(2,593 Views)
Okay, I was able output the data to a chart but how do I display all of the elapsed time? I am graphing frequency vs. time and it only shows a 17 second window. I want an overall graph after all the data has been acquired. Attached is my code file. Excuse the rough naming and aesthetics of the code, I want to get everything working then mess with that.
(2,588 Views)
