Extract a name/value pair array from flattened JSON
I've got a JSON string containing an array of name/value pairs:
{ "params":[
                   {"name": "Param1", "value": "10"},
                   {"name": "Param2", "value": "20"}
For the moment I'm extracting the whole array by iterating over the array index until an error is generated, as shown in the picture below.
This is not very nice as it always generates an error (could be ignored) and also the resulting array contains at the end an empty element.
(4,007 Views)
Accepted by topic author Batlan
Ok, found the solution myself.
Simply omit the path and enter as type a cluster with a named array ("params") ofjson_array_solution.png clusters containing a"name" and "value" constant .
(3,992 Views)
thx for this post, helped me to solve my problems with a similar problem !!!!
(3,899 Views)
