How to open or convert the LVLM2010.iso File I got from my download
I recently downloaded the LabView version with the NXT toolkit. I got an LVLM2010.iso file, but I can't open it or do anything with it. I do have WinRar. I can't use LabView in any form, i just got a .iso file. Any help is appreciated
Message 1 of 10
(6,212 Views)
An ISO file is a CD/DVD image. You can download and install 7-zip and convert it to a regular folder (right-click...). Then open the folder and run setup to install LabVIEW.
Or you can burn it to a DVD. What is your OS?
Message 2 of 10
(6,209 Views)
I'm using Windows 7. I only have to get this LabView version to open a block diagram someone sent me, so I can print it. But I only got this file and there is no LabView-icon on my desktop.
Thank you for answering so quickly.
PS: I'm not very good with computers, so I won't understand most abbreviations.
Message 3 of 10
(6,203 Views)
I don't know if someone could do this for me, but I'll just ask. I don't have to work with LabView (atleast not at home). I only need the block diagram to print it and to make a powerpoint, i don't need to change anything. Could I just send it to someone, and could that person send it a pdf file of the block diagram to me back, so I can print it and use it in my powerpoint?
I know this is a weird question.
Message 4 of 10
(6,187 Views)
You can attach the VI here.
Message 5 of 10
(6,173 Views)
I attached the file to this post. It would be great if you could send me the pdf version of the block diagram. It's not totally finished, but that doesn't matter, I can complete it in school.
Thank you, really, thank you.
I know that this is not the purpose of this forum, but it was the easiest solution for my problem.
Message 6 of 10
(6,168 Views)
Sorry, I need to find a computer that also has the NXT toolkit installed.
Message 7 of 10
(6,142 Views)
Can anyone do this for me?
Message 8 of 10
(6,127 Views)
There is absolutely no need to attach the same file twice in a row. All the information is in your earlier post.
(... and nobody would understand what "do this" means without going back and read the old post!)
Message 9 of 10
(6,124 Views)
Accepted by JordanG
Message 10 of 10
(6,112 Views)
