How to open a text-file with notepad from labview-vi?
how can i execute a program from a vi?
I want to open a textfile with Windows7-Notepad after selelecting it from a file-path-control and pressing an open-button.
Thx for help
(10,721 Views)
Put this in an Event case that handles the open button's value change.
Jim
(10,710 Views)
Use the command line.  Something like cmd /c notepad c:\temp\blah.txt should work.
(10,708 Views)
Accepted by OnlyOne
Another option is the Open URL in Default Browser VI which is found in the help palette. If you use the Path to String function you can feed it the result as a URL and the Windows shell knows how to direct it to the default program, which is Notepad.
Edit -
___________________
Try to take over the world!
(10,691 Views)
