How to name columns when writing to a file
(2,991 Views)
That really depends on the format in which you save. If you're using Write to Spreadsheet File, you can find instructions on its diagram for how to change it to write text files (don't overwrite the original VI).
If not, I suggest you post your VI and write some more details about your format.
___________________
Try to take over the world!
(2,979 Views)
   Using labview 7.1 Write Labview Measurement File how do you name columns
(2,969 Views)
Take a look at the example in the LabVIEW Help for Write LabVIEW Measurement File. It will show you a example that saves lots of information, headers, etc.
P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,963 Views)
My program is running.  I am using the Write LabVIEW Measurement File the express VI.  My numerical data is sent to a Microsoft Excel Sheet in columns, but how do I name each column in spread sheet.  It seems that the Write LabVIEW Measurement File only accepts numerical values.
(2,959 Views)
