How to move visible line of text-box to end?
i am logging text to a string indicator.
In the example 1000 lines with numbers 0..999.
What can i do that the visible last line of the string-indicator is always the last line i added?
(3,610 Views)
First off.... switch terminal and property node. Replace "value" read property node with a shift register. You waste tons of performance by the current implementation.
As updates are too fast for display, you should "autoscroll to end" after the loop. You can use the property "Scroll Position" in the Text-properties.
Norbert
Norbert
Expert: Geometry
(3,607 Views)
This was only an example to demonstrate my question.
How do i know the number of lines to use as input for property Text.ScollPosition?
(3,592 Views)
Accepted by OnlyOne
Use a big number and you're done. "+Inf" might be fine…
(3,589 Views)
You will want to give this thread a read through.
Darren's Weekly Nugget 06/28/2010
(3,577 Views)
An I32 "-1" works well tooSmiley Wink
"Should be" isn't "Is" -Jay
(3,558 Views)
