How to move the scroll bar of table
Thanks for your replies. Inserting data into table is working properly. Now I want to move the scroll bar of table as new data inserted into different rows.
Shivakumar Singh
(4,081 Views)
Hi Shivakumar
Try the edit position property.
Kurt Friday
www.sciware.com.au
(4,077 Views)
Thanks for your reply. Moving the scroll bar function working properly.
Shivakumar Singh
(4,074 Views)
You can make use of the EDIT POSITION property node of the Table for moving the scroll bar to the latest line of inserted data.
cheers
vicky
(4,074 Views)
This property doesn't seem to work to make the table scroll in LV8. Has anyone else tried this?
(3,950 Views)
Try using the "Index Vals" property.  I think that will provide what you're looking for.
(3,952 Views)
Hi Shivakumar,
use  the Top Left  Visible Cells  Property Node
kind regards
Mesut Sözüçok
(3,864 Views)
