How to monitor PXI CPU utilization?
Does anybody know of a way to programatically monitor CPU utlization on a PXI controller through LabVIEW? I know that NI had a proprietary VI to monitor memory usage called rtgetmemorysummary.vi to monitor memory usage, and I want to do the same for CPU usage.
Message 1 of 14
(5,405 Views)
bump
Message 2 of 14
(5,374 Views)
If memory serves me, I was only able to do that by connecting a display to the CPU.
Ben
Message 3 of 14
(5,360 Views)
Accepted by topic author sgregor249
If you are speaking of a RT targer, then you can use
RT get CPU loads.vi
See here
Marco
Message 4 of 14
(5,359 Views)
Thanks MarcoMauri thats exactly what I needed. I looked around NIs site and found out this this VI only appears on the palette if you are coding under an RT target.
Message 5 of 14
(5,347 Views)
This seems to only be available in LV 8.6+. My immediate needs are for LV 8.5, but this might prove useful for code that I need to support in 8.2 as well. Is there any way an NI applications engineer can backsave this for me? I see that it requires  ni_emb.dll and NI_Real-Time Target Support.vi. Shoot, on second thought I have a Main VI that runs both on windows systems and RT systems and introducing this to the windows system would cause the code to break. Perhaps I could use a conditional disable with target type to avoid this.
Message 6 of 14
(5,334 Views)
Unfortunately this function is not supported in LV 8.5 and to downgrade it to previous versions would, short story, break a lot of things.  Do you have a hardware limitation for being unable to have LVRT 8.6 on your target?
Message 7 of 14
(5,312 Views)
No hardware reason to not upcovert. It's more of a risk thing, plus it's not my decision.
The reason I wanted to log PXI CPU utilization was beacuse one of the PXIs in a 5 PXI system seems to randomly reboot about once a week. We've been replacing pieces of the system part by part(chassis, controller, cards) and verifying the electrical system(the only thing left is the PXI Power cable). I don't think it's the software because the same code runs on all 5 PXIs. The CPU utilization might be useful in getting to the bottom of this, but I doubt its the culprit. I would only argue for upgrading to LV 8.6 if we've exhausted all other options first.
Message 8 of 14
(5,302 Views)
If that chassis is a RT target then that is one of the signatures of a memory leak. When you run out of memory in a RT app it reboots.
Ben
Message 9 of 14
(5,295 Views)
The RT machine is running a build. We have code to log memory utilization and it doesn't increase prior to the restart.
Message 10 of 14
(5,286 Views)
