How to make the three boolean buttons work?
@ASIM_LAMBAY wrote:
Use cluster in place of integer input and in that cluster use 3 separate integer done.
That just make everything much more complicated! (more than three separate event cases, lots of duplicate code, more complicated code, harder to maintain, less scalable, etc.). I would strongly ignore that suggestion!
And what is "plaster"? Why is there a timeout case? Why is there no stop event?
Message 11 of 12
(736 Views)
@Gemi0673 wrote:
Hey @altenbach, I have tried this and did exactly what the picture showed but the buttons don't work on my end. If possible, do you mind uploading your file?
I assume you finished after correcting the errors I pointed out. For reference, here's the code I made: Modify as needed.
Message 12 of 12
(735 Views)
