How to make the search 1D array function case insensitive for string array
I know this thread is dead for 9yrs, but I was not satisfied with the answer.
See attached solution using OpenG tools
Message 11 of 13
(842 Views)
Since you revived the thread, I think most users should prefer the earlier approaches over yours.  Sorting a string array can be expensive and is generally not needed or even particularly helpful to the goal of string matching.
(This is distinct from the way that maintaining an array in sorted order might be useful to support lots of lookups using a binary search algorithm.)
-Kevin P
Message 12 of 13
(832 Views)
Variant Attributes does this for you!
As far as the searching in a text array, I have a tendency of using Trim Whitespace followed by a To Upper.  I trim the whitespace because I have seen too many users accidentally add in a space or end of line to the input and then complain to me the strings won't match.  To Upper or To Lower: you can use either one as long as you are consistent.
Message 13 of 13
(825 Views)
