How to make stop button to work again in a while loop
Gu,
Get rid of the local variable for stop2 - just use the terminal. Then, inside your event loop, just use a constant to send the value to exit that loop. Finally, use a latching action on stop2. This will eliminate your need to hit stop2 twice.
Message 21 of 27
(840 Views)
Hi  Johntrich1971,
Thank you for your suggestion.
Could you please modify my VI and upload it? I do not fully follow you.
The local variable Stop2 is to stop both upper and lower loops on the right simultaneously.
Gu
Message 22 of 27
(831 Views)
Gu,
Yes, I understand that. The event structure will still fire even if the stop2 button is not inside it. You would then just use a True constant where the stop2 button currently is. This will stop both loops.
Message 23 of 27
(828 Views)
Attached is my rev showing the suggested change.
It should be easy to convert this to a state machine also - an MUCH more maintainable.
Message 24 of 27
(825 Views)
Hi Johntrich1971,
My LV is 2015, could you please convert your VI to 2015 compatible so that I can open it?
Gu
Message 25 of 27
(805 Views)
Accepted by edmonton
Here it is in 2015.
I encourage you to try to make the changes to your code yourself so that you can get a better understanding of how these things interact.
Message 26 of 27
(798 Views)
Hi  Johntrich1971,
Thank you.
Gu
Message 27 of 27
(781 Views)
