How to make indicator transparent?
hi..
i have attached a word file regarding ur requirement. If it's compatible u can use it.
Message 11 of 25
(2,249 Views)
Yes, this will work. Remember this is only for one state of the boolean.
Message 12 of 25
(2,243 Views)
Ya thanks... 🙂 Smiley Sad
Message 13 of 25
(2,239 Views)
Why the sad face?
Any succes ?
Message Edited by K C on 09-24-2008 02:12 PM
Message 14 of 25
(2,237 Views)
No not yet... It's time to go home.. That's why.. Will try on 26th.. 🙂
Message 15 of 25
(2,232 Views)
Ok, I will try this at home with 7.1 and let you know the result. Till Friday.
Message 16 of 25
(2,231 Views)
Accepted by Rupali
Just like I remembered it, it works the same way in 7.1 even in 6 it was is the same. Smiley Wink
Message 17 of 25
(2,208 Views)
K C wrote:
I can go back to 8.0.
So, it is better to backsave the VI during devp itself to LV 8.0, so that most of the people can 'see' it. Smiley Wink
I use LV 8.5, but mostly backsave it for LV 8.0 while posting in the forums. Smiley Happy
Just a suggestion...
- Partha ( CLD until Oct 2027 🙂 )
Message 18 of 25
(2,197 Views)
That's good one partha.... Smiley Happy
[Edit : Kudos for you]
Message Edited by mathan on 09-25-2008 03:28 AM
Message 19 of 25
(2,186 Views)
hi K C...
sorry i couldn't understand ur words..Can u plz explain once again....
Message 20 of 25
(2,155 Views)
