How to make exe of program
Dear Sir,
Please tell me, any person who don't have install labview, want to test the readymade program's for some files.
 base on that need how make Exe Of the program.
(3,187 Views)
for that you need the application bulder.
https://www.ni.com/en/support/downloads/software-products/download.labview-application-builder-modul...
Learning LabVIEW since January 2013
(3,185 Views)
If you have the professional version of LabVIEW or the application builder option, you will need to create a project.
At the very bottom of the project explorer window, you should see "Build Specifications".  Right click on it and select > New > Application (EXE).
The most basic configuration will require that you select the startup VI in the Source Files.  Explore the other areas as you may need additional configurations.
(3,169 Views)
(3,156 Views)
The client computer will need LV runtime, which can be downloaded separatly, or included in the Installer, which is created the same way as the .exe
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,148 Views)
