‎06-05-2013 06:24 AM
Dear Sir,
Please tell me, any person who don't have install labview, want to test the readymade program's for some files.
base on that need how make Exe Of the program.
‎06-05-2013
06:30 AM
- last edited on
‎04-11-2025
05:28 PM
by
Content Cleaner
for that you need the application bulder.
‎06-05-2013 07:53 AM
If you have the professional version of LabVIEW or the application builder option, you will need to create a project.
At the very bottom of the project explorer window, you should see "Build Specifications". Right click on it and select > New > Application (EXE).
The most basic configuration will require that you select the startup VI in the Source Files. Explore the other areas as you may need additional configurations.
‎06-05-2013 08:27 AM
‎06-05-2013 08:41 AM
The client computer will need LV runtime, which can be downloaded separatly, or included in the Installer, which is created the same way as the .exe
/Y
