How to make check box as one colume in a table display
Need to make user for select.
Any suggestion, thanks.
(2,887 Views)
Please do a search. This question has come up many times. Search for "dropdown" or "menu" or "pulldown" or "ring" in a table. You will see various solutions proposed.
Note: this applies to checkboxes as well.
Message Edited by smercurio_fc on 06-01-2010 10:57 AM
(2,875 Views)
just quick hint can be design the array of cluster having control defined horizontally.. then pass the 2d array of empty string to table.. now use position and cell size to synchronise..
hope it helps
HS
(2,855 Views)
