How to make a sql temporary table
Hi
I would like to create a temporary sql table - "create table #tempTable...."
but I get error
Is it possible to do it with Labview DB connectivity toolkit?
Thanks...Eran
(3,756 Views)
Accepted by Eran1965
I know you can create a stored procedure and execute it from within LabVIEW.  And within the stored procedure you can create temp tables.  I like this method because you can easily change the SP code without recompiling your VI.  Hopefully this helps.
aputman
(3,723 Views)
yes, This help !!!
(3,706 Views)
