How to make a *.iso file for cRIO target
Hi all, I've a problem. I need to test\update a project designed for cRIO 9045 target but at moment a real target is not available so I try to found a different way.
An alternative, not a full alternative, could be use a VM to emulate the real target but to make the VM is necessary the *.iso file and the RDA tool generates a *.lvappimg file.
Do you Know how obtain the iso RTOS immage from real target or other source ?
Thanks in advance
(2,237 Views)
Accepted by zundap1970
You might try taking a look here for some discussion of RT-OS simulation: Provide a Virtual Machine to run LV-RT systems
GCentral
(2,196 Views)
Thanks but the main problem is about the RTOS immage, I read several discussion about this a seems possible use a VM but to make a VM I need a *.iso file of Lunux RTOS and RDA tool doens't provide the *.iso immage.
(2,168 Views)
Does this help? NI Linux RT System Image
There's also the offline installer which might be the actual ISO (at the very least, it is AN ISO).
GCentral
(2,162 Views)
