How to lock boolean data indicator
Hello Guys,
Good night,
I have a problem with boolean indicator(lamp)
In my project,
When the value > 7 the lamp 1 turn on
When the value < 5 the lamp 2  turn on
i want,
1. If the value > 7 lamps locked, so before the value < 5 the lamp 1 always on
2. if the value < 5 lamps locked, so before the value >7 the lamp 2 always on
Sorry 4 bad english,
Nb: vi on attach post
Stewkidz
Message 1 of 9
(5,367 Views)
(you might want to add a small wait into your loop)
How does the value change over time. What is the initial value? All you probably need are two shift regsiters that keep history information.
Message 2 of 9
(5,343 Views)
If I understand you correctly, all you need is a couple Shift Registers.  This will turn 1 high if the value exceeds 7, and it will not go low again until the program is restarted.  The same works for turning 2 low when the value goes below 5.
Jim
Message 3 of 9
(5,321 Views)
The way I understood it was that the >7 LED should turn off once the value goes <5. In your code is stays on permanently.
(Granted, the problem description is not entire clear and leaves out some scenarios. That's why I asked for clarification)
Message 4 of 9
(5,317 Views)
Accepted by StewKidz
See if this works as you expect.
(Note that certains things could be improved by using compound nodes, but this code is more clear. There are many ways to do this. I would probably use an array of two booleans in the shift register and only one each for the boolean operations)
Message 5 of 9
(5,309 Views)
Here's one possible array solution.
Message 6 of 9
(5,301 Views)
Message 7 of 9
(5,279 Views)
Those are Shift Registers.  Right-click on the output tunnel and select:
Jim
Message 8 of 9
(5,267 Views)
It works equally well with input tunnels. Many times there are no suitable tunnels yet, then you  just right-click on the loop frame and select "add shift register".
(Creating a new shift register is actually easier for the inexperienced programmer. If we convert an existing tunnel to a shift register, it is more complicated because we need to immediately decide to either pair it with another existing tunnel of opposite direction or  create a new other half).
Message 9 of 9
(5,250 Views)
